zacksc
I have been trying to develop a practical, empirical understanding of power flow and phase current in an e-bike system and I'm thinking that maybe understanding two particular scenarios could be a good start. For specificity, let’s say we have a Bafang G310 motor (standard winding) controlled by a Baserunner (powered by a 36 volt battery), and let’s consider two particular riding situations:
1) bike is moving on level terrain at a constant speed of 10 miles per hour. Battery current is about 7 to 10 amps. (throttle voltage roughly 1.9 volts.)
or,
2) bike is going up a steep hill at very low speed (3 mph). Battery current is 20 amps. (Throttle voltage is maybe about 2.4 volts.)
So here is what I would guess, and please tell me if this is all wrong: I think that in case 1, where the bike is moving freely, the current might lag the voltage significantly; the power factor might be as low as maybe 0.5 perhaps? Is that accurate at all?
In case 2, on the other hand, going up a steep hill, I am wondering if the load becomes more resistive and the current lag becomes less, bringing the power factor closer to 1 in this high load situation? Again, I am not really sure if this is correct at all and would love feedback.
I would also like to understand a bit about power loss, i. e., heat generated in the controller and in the motor. I am thinking that in the low-speed, high torque situation, the motor is not very efficient. If, for example, the motor efficiency is 0.8 in that torque-speed situation, then the heat generation rate would be about 140 Watts. (0.2*I*V, where I and V are the dc battery current and voltage to the controller, respectively.) Is that in the right ballpark at all?
I am thinking that the heat loss in the controller is mostly I2R loss associated with the resistance of the MOSFETs (about 4 milliOhms) and therefore tends to be relatively higher in low power factor situations where the phase current is high relative to the motor wattage? Would love to get expert feedback here and improve (or begin) my understanding. Thanks.
or,
