azisme
Yes I know this has been discussed over and over again on this forum, but I want to be absolutely sure I am wiring up my new batteries correctly. I also want to post the drawing I made to help out others following a similar path.
I have ordered and received two custom 30 volt 15Ah batteries and two custom 37.5 volt chargers from Ping. I am going to hook them up in series for a 60 volt, 15Ah hour system. I already have a controller that is rated from 36 - 72 volts and a Crystalyte 408 front hub motor.
My first question is: does the schematic look correct? I am 90% sure it is, but I have a lot invested so would like some additional reassurance.
My second question is: Can I leave the batteries hooked up to the controller while I am charging the batteries? Can the controller still be turned on while charging or do I need to put in some kind of safety to make sure I don't forget to turn off the controller while charging?
