outbackhack
Thinking of taking the plunge and attempting to split one of my Ping batteries in half for v2.0 of my ebike. I want to keep the battery almost entirely in the front-triangle, but this time keep it narrow enough (4" instead of 6") that I can pedal comfortably and the only way to do that is going to require breaking the pack in half.
I removed the shrink wrap and sized up the task last night. Before I start cutting&soldering I wanted to see if anyone here who has experience with this packs can confirm I am cutting in the right place and approaching the task correctly.
Here is my pack, how I believe it is configured, and where I am planning to cut. My plan is to use a dremel with a thin cutting wheel to divide the board joining groups 4 & 5, solder 1m of 10g wire to reconnect 4 & 5, and then repack the cells into 2 separate enclosures.
2012 Ping v2.5 48v 20ah (2x 8s4p 5000mah lifepo4)
