electricridefl
- Joined
- Jan 5, 2008
- Messages
- 374
Hello all. I built my current ebike several years ago. I have a clyte rwd 409 26". I bought 2 ping 36v10ah lifepo4 a year or 2 ago when ping first started selling on ebay. The batts are conneceted in series for 72v. My controller limits current to 20amps. The batteries have performed flawlessly since then...until now.
I was commuting daily 10miles total each day. Pretty much full throttle most of the time. 30+mph and 15+ mile range. And also ride during freezing temps in winter. Charge batteries outside. So no problems until I stopped riding my bike. I notice batteries losing charge from sitting. The power is off. I charge. After batteries sit idle for one month, they are completely dead. I measure voltage over 60v and then when turn power on, voltage dropped to about 15v, so bike did not run at all. So I charge up for 4 hours. So then I'm all set, and head out down the road. But I only get 20 feet, then power cuts off. And no power until I turn off power switch, and then turn back on. Then bike will go until I twist the throttle and then shuts off. I test controller with power at rear wheel while stalled. The controller cuts off, then turns back on, like usual. I connect voltmeter to blue (charger) and red wire to measure voltage with rear wheel in air and spinning while rear brake applied for load. The voltage in each 36v10ah battery holds around 40v through shut-off. The power will only return after my main power switch is flipped off then back on. I noticed I had to do this previously when power cut off on me before as I reached 15 mile range. I have no diodes between my batteries in series. All of the cells in both batteries seemed to self discharge equally and completely when sitting. I would venture to say that this self discharge is related to the age of the batteries. The only other thing I noticed after cutoff after my 20 ft ride was a tiny hot spot in each of the battery's
bms'. I have the first version of pings I think, but they have a better bms, allowing for 2c continuous current. The batteries have less than 500 cycles on them.
They have been sitting idle now since January. They will not work at all. Well, they will if no load applied. And they will self discharge fairly rapidly. I will connect each 36v battery separately to test each separately at 36v to check equality and operation and cutoff amps. I will then bypass the discharge bms and then monitor the voltage under load. Like I said, the batteries were fine until left to sit for a couple months. Supposedly they should last for thousands of cycles. Now when they were completely dead (60+v), I put on charge (a ping charger for each). I went back to check 4 hours later and the charger lights were green and they were not very warm. The chargers output about 1.3amps each, so it would appear that they did not charge anywhere near the time required for 10ah. I had high hopes for these batteries lasting me a while...My initial gut conclusion is that the batteries are done...I sure hope this is not the case. I will test further.
I have not kept current with posts here. Has anyone else experienced an extremely short life with pin batteries?
