SamTexas said:cell_man said:Hi Sam,
sorry to but in, but the 350W kit is intended to be used at 36V, not 48V. It has a 17A controller, so over 800W max if you run it at 48V. I don't recommend you over volt these motors and controllers.
Not a problem at all, Paul. In fact I'm glad you joined the discussion. Here's how I plan to use my bike with your 350W front hub: I will always be pedaling. The motor will be assisting me on uphills and in headwinds. I envision the average power consumed by the motor to be around 250W, hopefully much lower than 200. Obviously, there will be short burst of powers, but I doubt I will ever reach the max 816W imposed by your controller. The battery pack 15A rating is the "CONTINUOUS Max Discharge" while the "Maximum Discharging Current" is 30A (1440W at 48V). So I should be within the operating parameters, right? Since the motor and controller will mostly be underutilized, I don't anticipate overheating problems. Or am I missing something?
I'm fully aware that your kit is intended to be used at 36V. I want to use 48V because the same battery pack might be used for some other future toys as well.
dogman, I welcome your thoughts on this too.
cell_man said:The controller will hit the current limit quite easily I can assure you. You are staying within the operating limits of the battery but by overvolting the motor and controller you are not staying within those of the motor and controller. Will it be ok, probably, but if you don't want the additional speed or power stick to the standard 36V that it was intended for.
You have it about right, the controller will feed 17 amps. So increase the voltage, and you increase the wattage. Every time you start, the pingbattery will supply 52-58v ( 48v ping charges to 60v). that 56 volts or so will flow at at least 17 amps till you get rolling. So you'll pull almost 1000 watts for 30 seconds or so. Then for another 30 seconds you will pull at least 2/3 of that, Say 650 watts. So if you stop throttling then completely, you'll be ok. In the real world, though, people don't, and use about 600 watts to cruise at 25 mph. Cruising on 36v, at 20 mph wattage may only be 350. So you see the 36v setup is better for the long haul.
The problem is when you come to a big hill, or ride too far. You should be easily able to kill a small gearmotor with the capacity and wattage of a 15 ah 48v ping avaliable, and the ride has some good hills.
If you do go 48v, then you really should be monitor ring temperature of the axle stub, and stop if it ever gets above about 140 F on the stub.
