Hi All,
Collecting parts for my first ebike. recently ordered a BMC v2C motor. currently looking at these Turnigy batteries from Hobby king (22.2V 5A.hr) - would require 12 of (3x22.2V=66.6V and 4 x 5A.hr= 20A.hr) - not sure best wiring setup to enable foolproof charging / operating wiring configuration swapovers. http://www.hobbyking.com/hobbyking/store/__9176__Turnigy_5000mAh_6S_20C_Lipo_Pack.html
The alternative I am looking at is a ping single pack battery. http://www.pingbattery.com/servlet/the-20/60V-20AH-V2.5-LiFePO4/Detail I'm not sure which will give better battery life - lowest $/kW.hr x recharge cycles is attractive. The hobby king appear to be better for high discharge/recharge rates but my build is mainly for longer range (50+km) rather than high kW motor draw . The single charger from the ping is attractive. less hassle to recharge. I'm not convinced the ping charger provides equivalent battery management to multiple turnigy chargers (or similar). [ie http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=7028]
As a side note, I'm leaning towards 60V20A.hr instead of lower V & higher A.hr due to keeping the option for higher burst power for hills and keeping the Amps down - lower heat in motor and lower discharge rate from batteries will result in more efficient battery use. (as I understand battery chemistry behaviour) Good insulation practices obviously will be important - will be using a rated isolation switch and considering a rated Amp trip switch as well.
Given battery pack failure will inevitably involve an individual cell failing - the ability to take a cell out and continue to use the pack until a cell is replaced is VERY attractive. similarly the diagnostics on individual battery cells available with battery monitors does not appear available with the ping battery.
I saw a photo once of a plastic block machined with wiring connectors that enabled easy quick swapping of battery pack wiring from charging multiple individual packs to connection as an assembly for operating. Haven't been able to find it again.
thoughts/advice appreciated.
