Please help me to learn solar inverters, and what I should look for.
I want to patch and assemble a solar system from used parts for my home, and routinely used solar inverters appear on Govdeals- mostly from technical colleges and electrical programs who are swapping out used ones for newer tech with updated features. I've tried to learn what I can about them, but I keep running into issues with their rated or set voltages that I don't fully understand.
My first question is: This Frontius IG Plus inverter is nearby and I THINK it can be used for a personal home environment? it seems I can set it for 240v Two-phase (thus being able to power each "leg" of 120v outlets in a standard panel) but it claims to be a 10.0, which recommend a PV installation of anywhere between 8.5-11.5 Kw; which I don't think is even possible for my roof or area thanks to my treeline. The cost of these is anywhere between $3,500 to $4,000, but am I right in thinking it's not worth buying (unless extremely cheap!) because I can't physically put enough panels on my home to make it worthwhile?
Next is this Solaredge unit, an SE20KUS. Because it's rated for 277/480v 3-phase- and American homes are technically 2-phase with neutral and ground- there's no way I could use this for a home environment correct?
Thanks!
for sure the 3phases 277-480v won't be working for north america homes. It is for 120degrees between phases but your home is 120+120 with 180degrees between phases...
I don't know any of these modules, you may search to find the user manual online of the first one...
There is many models of solar controllers, inverters, chargers etc...
1-The more basic is strickly an inverter that generate ac power with your battery power. You need a separated charger to charge the battery, you need a separated transfert switch also to switch from grid to inverter. and if you want to add solar recharge, you need a solar controller separated for it.
2-There is inverter-charger. They don't manage the solar but add some benefits to the previous one, 1 unit charge the battery on grid and supply the AC load when grid goes off automatiquely with a built in transfert switch. For solar, you still need a separated controller
3-The all in one unit do like the above and it add solar control to either just charge the battery or directly supply the AC load. It is complete but if it burns, you lose everything and usually it will require higher solar voltage with less current than some stand alone solar controller.
#2 + a solar controller remain the more flexible choice but #3 is often more cost effective...
Then the size....i live in the nort of north america and if i would run all my house on one inverter, it would be at least a 20kw with load limitation or i would need larger. i monitor sometimes 15-20kw loads. Then i would need battery the size of EV battery of 75-100kwh since i run about up to 90kwh per day with 60 average....
What i did instead, is to select which load i really need during power outage and i moved only those loads in a separated 60a breaker panel box. (I wont use electric heaters during outage but my wood stove and i won't run the spa on battery either so i didn't moved those loads.) i moved about half of my outlets and more critical loads with it to get lights, tv internet etc.... This reduce the size of emergency backup system while being able to run everything else on the grid without limitatiuons.
I was first looking for a 120v 5kw that would have worked without my water heater.....but last winter we did lost power for 6 days and i had to make a redneck temporary connection to get hot water so i decided instead to pay more and get a 10kw split phase and include the water heater..... (I also have a 120/240v generator with it to extend the runtime so a split phase inverter was more friendly to ba compatible with everything else. I actually just have 3.5kwh or lifepo4 but at 20C it can supply the inverter power for some time....i would need more if i wouldn't use the generator....It is a work in progress....I didn't installed the solar panels yet.
I made another install with a 120v 5kw inverter but i jumper both sides of the emergency breaker panel. it isn't designed for that bu i modified it and it was out of grid completly for a house in the wood. using propane for heating, it work all year with just 2.4kw of solar panels and 5kwh battery.
For solar sizing, it depend what you do with it. You will want MPPT controller for better efficiency
For a separated controller, you can get panel nominal voltage slightly above your batteries. for a 48v nominal system for example, you need at least 2x 24v panel in serie but 3 would be better to keep charging when sun is low. You also need a controller that can handle the peak voltage of the panels in serie....usually 24v are about 39-40v no load peak voltage in standard conditions and could rise higher if under very strong solar energy. so you need in this case a 150v controller or better to be safe.
With a all in one unit, you would generally need higher voltage so more panels in serie. there would be a range specified in the unit manual. It is usually higher with less current for same power(Not sure if standard but all the one i checked was higher). keep in mind, if you set just the minimum range with your panel nominal voltage, it will only work when solar energy is enought to reach that voltage. Better get 1 more panel in serie to help it as long as you don't exeed the maximum peak voltage in open circuit like with the separated controller.
For the number of kw, many factor come into play. how many hour of sun do you have a day. the size of the battery and how much energy you need during the day. I personnaly calculate about 4hr of sun per day all year long because where i am, there is not much sun during winter. This way, i need at least 1/4 of the battery to keep them charged with 4hr of sun + what i would use during the day. So far the 2.4kw of solar with 5kw battery seem to work well for the second install i made. they forgot about the spare generator since i installed this. They have to think about starting the generator to keep it in good shape because they don't run it.
Thank you for the explanation Jeff. Solar's kind of a lot and from what I've found, and your statement of going MPPT for the highest efficiency I agree with.
I'm going to keep looking at the secondary market, because nearby a used Growatt 3KWH combo unit (MPPT, inverter, battery charger) can be had for $700 from people getting rid of older systems. Since I don't really know how many panels I can actually put on my roof- which doesn't even have mounting brackets- I think I'll go the 3-5Kw route and only consider the 10+KWH boys if I can really steal them for a low price.
CS,
How will you use your solar?
Are you allowed to sell back excess power back to the grid?
How much space do you have for solar panels?
To give you an idea:
In MI where I live the quote to sell back excess power has run out. So if I put in solar, either I have to use ALL of it or store the excess in a battery bank.
Ebiker know well how $$ and mess batt systems can be.
I have 14kw of batt for my Transit van. I charge it via electricity.
Payback with batteryless solar system is faster but those won't provide any emergency solution for a blackout when sun is out. I wonder if the grid company tell peoples which inverter to get to be allowed...i never digged into this because with instability of the grid in my area, systems are for emergencies more than saving.
And i would expect this kind of netwoork need a balance between house providing solar to surrounding facilities / work shops. Someone needs to cunsume that solar energy provided during the day when mostly everyone is at work....That could be the reason why they aren't allowing more providers in your state ?
Batteries system are perfect for blackout when the sun is down. Even if it is adding extra requirements, I do prefer this than the above.
I think we better not use the ebike li-on cells for home battery to save some hassle.
Lifepo4 are more stable where space and weight isn't a problem. Even if those are usually limited for peak current, it get a better lifespan. (thousands of cycles vs hundreds for ebike packs)
Who's going to do the solar install? On a DIY solar install it is next to impossible for amateurs to pass inspection. Might start reading the latest NEC code that your jurisdiction is using, or find a solar install electrician. Off grid, and in the boondocks you might get away with it. Also, solar panels on, and electrics in an outbuilding gives you some leeway in your install.
Jurisdictions now use drones to look for buildings with code violations. Solar panels are easy to spot from the air.
good point. Unions and agency are checking and your insurance company also... For many case it is a good thing....
Are you thinking more against mechanical installation non conformance or the electric part ? Some electrician can work with part of the job done by yourself, according to how busy they are...
Many have done self install, the sellers provider a details diagram and other stickers etc to pass inspection.
when I was planning on installing, I had a electrician lined up to install the main disconnects etc.
The electric co in Michigan is a monopoly, law makers hold their ankles for big business in MI. We (taxpayers) paid for wind farms, that does NOT generate any power,
back on topic:
Solar is totally worth it if:
1. Cost to pull power to your location is $$$, when I looked at property in CO, $5k a pole to get power, 10 poles or more.
2. Price of LFE is going down and supposed to go down even further, I consumer 20 kw a day, I would size mine to be 70kw of batts and 20kw of solar
3. Used bifacial panels can be bought for $0.2x a watt,
Sit down and crunch some numbers and if the cost of getting power or solar makes sense.
CS,
1. I'll use it more to learn and prepare for much bigger systems I want to make down the line. I don't see a future of total self-reliance, just that I think I can make small systems for a few hundred to a thousand that will pay for themselves quickly and give me lots of hands-on exprience.
2. Yes, I can sell back excess.
3. HARD to say. If you think of a small valley, my property is basically facing the sun on the hillside that rapidly 'ramps' upwards- but it's surrounded by large trees, and with the sun's angle there's some portions of my roof that Don't get light depending on the month. The usable half of my roof is "okay" per project Sunroof (estimates 1,000 sq/ft max for panels) but it doesn't give an idea of the sun's travel through my property for ground-mount, which is what I REALLY WANT because my roof has no mounting hardware and I plan on using used materials.
I'm honestly wondering about making some kind of compilation picture system, where I can assemble photographs of my property throughout months in a slideshow to get an idea of where and what gets the best sun for this idea.
Can you elaborate more of the use of your power? I'm curious, i know you need less energy than me for heating (IM north of you a bit) but is all your stuff is electric or you have gaz/propane for water heater and stove (or else) to limit your electric needs to just 20kw/day.
I did install a monitoring system on my and i'm happy when i run around 45kw/day and it rise at 75 sometimes during weekend when we do all washing and more use of electricity. I don't have gaz but a wood stove for winter heating as a secondary system. I do have a climate/heater thermal pump + electric heaters as a primary system. water heater and cooking is all electric. But i also have a spa running all year above 95f but a thick cover is kept closed when not in use.
Next i will monitor separately how much the spa is using but i didn't see a significant increase for my bill once installed. It was the same year i got the thermal pump so maybe, i use the saving of the pump to run the spa...
I check to get efficient device for everything i would buy, like Leds everywhere and I would like to compare since HydroQuebec (our grid) website is telling me that i'm not that bad. But against your 20kw i feel the need to double check.
For reference, I use natural gas for cooking and hot water. I do not use air conditioning. And my usage per day is 4-12kwh. Maybe a very heavy electric day is 15kwh. So, 20kwh per day is totally doable.
