Hi all!
I have a 42V/17Ah (LG 18650 cells) battery and am now having issues with the battery.
When in use, the battery voltage will not be stable but will constantly vary between 42V and 20V something. This occurred less when the problems started and now, a few months later, the battery will not function at all most of the time. When connected to the bike, the battery voltage will be unstable and the display will show that the battery is empty. If removed and voltage checked with a multimeter, it will show that the battery is in fact charged and the voltage is stable. I have another battery and the bike runs fine with that, so that should isolate the issue to the battery. The battery is 2 years old.
The battery does charge ok and will display a normal voltage of 41.8V after a charge. Just like it did when new.
I opened up the battery case and tried to look for any bad connections or poor soldering. All looks good. I also ran a multimeter through the cells and they all have a 4.18 or 4.19 voltage.
I am wondering, though, if it is possible to measure the voltage of each cell individually when they are stick welded together. I believe I am in fact measuring the voltage of 10 cells connected in parallel. If this is so, and the reading is 4.18-4.19. shouldn´t that be an indications that the group of cells are ok?
I know very little about electronics and would very much appreciate if anyone could advise me what to do to troubleshoot the battery as far as it is possible with a mutlimeter and visual inspection.
Thanks!
Tomi
Thanks!
Tomi
