minime said:
Hello everyone
I am looking to buy a new e-bike and would like your advice.
I live in the UK and I recently purchased my first, road-legal e-bike, a Cyclamatic CX1 (250w motor, 36v/8.8Ah battery) for 450 GBP from thesportshq.com. I find the Cyclamatic lacking in many ways and would like to get a new e-bike that meets the following requirements:
1. Bike type: Mountain
2. Max speed: at least 25mph (I intend to restrict the top speed to 20-25mph but I might destrict it from time to time)
3. Max Range: the greater, the better
4. Torque: the greater, the better
5. Budget: 1500 GBP (at most)
6. Rider size: I weigh 165 pounds at 5' 11" and usually carry a 10-20 pound backpack.
7. Terrain: mostly flat roads with asphalt
8. Waterproof (even though I'll avoid riding it in the rain).
9. Frame size: 18" - 20"
Thanks
So as others have said, I think you indeed would get far more value for your money if you were to build your hypothetical ebike as a DIY project. The other greatly valuable thing you would get out of the experience is a much better understanding on how an ebike and all of it's components work. By DIY, you are educating yourself on it's workings, and will be in a much better position to repair it WHEN it fails.
If you just want to pay someone else to build it (whether a standard "off-the-shelf" ebike, or a custom "built to your requirements" ebike, expect to pay about 2-3 times what you could build it for by purchasing parts and assembling yourself.
If you build it yourself, I think 1500 GBP is probably a pretty reasonable budget.
One of the least expensive options would be to get a 1000W DD Rear hub motor kit from ebay/alibaba. These kits (at least in the USA) sell for about $250 USD and are generally pretty straight forward to install. Add a 48V battery like the Hailong ("Shark") style packs, made with Samsung 30Q or 25R or Panasonic PF cells, and that is capable of outputting 30A to the controller, and you pretty much have a rock-solid ebike set-up for well under $1000 USD. This set-up is a great building block, as each component is relatively easy to upgrade individually, if your needs change.
Want more torque: Upgrade the controller to a 40A version. (Though it would also be wise to upgrade the battery, in that case to one that can output higher current.)
Want more range: Upgrade the battery to a larger capacity Triangle battery (48V-20AH+)
Want higher speed: Buy a higher voltage battery (72V, depending on what your controller supports)
Want higher performance overall: Upgrade the motor to a wider stator version. Something like the Leaf 1500W or the MXUS 3000W, and also plan on getting a better controller and battery.
The thing to keep in mind in general, is that the motor performance is largely dependent on the battery's ability to output power (read CURRENT) and the controller's ability to "push" that power to the motor. In other words, you could buy the most massive "5000W" motor, and choose to feed it low power from a wimpy battery and controller, and the motor will perform like a smaller 1000W motor, because that's all the power the motor receives. Likewise, you can take a "1000W" motor, and feed it ridiculous amounts of power from a high-performance battery & controller, and it will perform similar to the "5000W" motor (up to the point where it overheats). The main difference between the "1000W" motor and the "5000W" motor is it's ability to handle higher current, and the time it takes to overheat.
I go into much more detail about all these aspects of motor/controller/battery on my website. https://kinayems.com/Support/HowFastHowFar
