Also called "mid fat" and semi fat" in the media.
I have been noticing tires that are around 3.0-inches wide, mostly in 27.5 and 29'r wheels, but...if they catch on you will be able to find them in more places and more sizes of wheel (20, 24, 26-inch?). I really like these a lot. I am mostly interested in street tires, but the best selection right now seems to be for off-road (I found one beach cruiser tire so far)
An example that I have seen in several articles is that...if you own a 29'r frame, then: a 27.5 wheel with a 3.2 tire is the same height as a 29 X 2.2 tire. This way you get "some" of the benefits of a 4.0 fat tire, with less of "some" of the drawbacks.
Here an article with more info:
http://www.bicycling.com/bikes-gear/mountain-bike-tires/plus-size-tire-primer
The pic below is a 2.8 tire on a 50mm wide rim. There is almost no side bulge, so it would have worked on a narrower rim. My readings have found recommendations of rims between 35mm and 50mm, for the spread of 2.8 to 3.2-inch tires.
