Hi
A couple of months ago I noticed that my bike with a 52v BBSHD rarely passed 50 km/h, something it normally did everyday at least in one direction going to work. It was like my speed was reduced about 5-7 km/h. So, I thought maybe things needed some lubrication. My rear hub (Shimano Nexus SG-C7000-5D) was due for first service but I didn't expect it to be the cause. The mechanic said it was in good shape. So, I then greased the motor. Opened the BBSHD and greased the stuff around the main shift in accordance with many Youtube videos. I used Mobil Mobilith SHC 100 grease. I did not strip it down to the nylon gear since I had no real strange noises or similar problems. But nothing improved top speed. The front hub is not turning perfectly without friction, I have been running at 50-55 km/h with really crappy not-so-lubricated hubs before so I doubt that is the cause.
So then I started thinking about the battery since it had 2.5 years of quite heavy use (100 % power about 5 miles per day 5 days all year, and 10 miles total) and no smart smart charger so always 100 % charge. But as I was contemplating this I burned the main battery contact (later I managed to fix it) and ordered a UPP Polly 25 Ah Samsung 5000 battery (40A continuous). I was expecting that to lead to a significant rise in both capacity and power/top speed since my previous battery was a noname 30A 21 Ah battery. But nothing improved. Today I installed the Daniel Nilsson firmware and controller software and upped the maximum current to 33A which the controller (and battery) apparently should be able to handle. But I still didn't get any more power and it actually behaved quite strangely. It might be a faulty battery but what could be other causes for decline in power apart from the battery?
