I'm certain your gearing change will pick up some mph, but as Luke so eloquently explained you're better off delivering maximum thrust as early as possible in the run.
Why did you not have phase current at 100% with previous gearing? Did it wheelie? Wheelspin?
Inevitably your potential performance will be limited by absolute power production, but this absolute limit is not the one that people run into first. Usually the problem is an inability to use available power when it matters most, right at the beginning! You have obviously done a lot to maximize your acceleration potential, but if you're serious about lowering that record (congratulations by the way) then that is where your biggest gains are still to be found.
If you're spinning the wheel, you need to gain additional traction by lowering tire pressure, reaching optimal tire temperature or using stickier rubber. If you're lifting the front then you need to deliver more leverage to keep the front down by moving CG forward. You can achieve this by relocating mass or you can increase total length. In your situation it's very possible that by carrying a LARGER battery you may reduce ET, because this mass is able to be located in an ideal location (as far forward as possible) and as it's active mass it reduces losses, delivering more overall power.
How much does the whole bike weigh currently?
