TylerDurden
Park Tool makes good stuff. But sometimes you need a tool after the bikeshop is closed.
The other night I got a burr under my saddle about freewheels, so I needed to improvise.
Freewheels have various slots and holes... Sometimes, I will add more to use conventional or improvised tools: I used a rotary tool to grind slots in the bigger FW to use a piece of steel (mower-blade) for removal.
I usually clamp a tool in the vise and put the FW on the tool and turn the wheel... good leverage. Many shops do this with FWs. You might have a piece of steel around that fits the job already.
Covers often require a pin-wrench, for the little holes.
I ran a couple of drywall screws through a long piece of scrap 3/4" plywood, and cut them off with a dremel. If you dont get the distance right the first time, no biggie... run it through again just to the side of the first.
I used MAPP to heat the parts, to free them up. Painted parts can be a pain. Use heat sparingly, it can corrode races. It will burn the grease, so you will need to repack.
