mortifiedMORTY
- Joined
- Nov 17, 2014
- Messages
- 23
Hi, thank you for looking at the topic. I've run into some trouble wiring my new setup. Honestly it'd be a bit hard to explain so I made a picture!
So the top image is my current setup. My problem is that the jumper connection I soldered in only disconnects one battery. With the parallel setup I'm using, this will be a problem as I can only disconnect the ESC down to half power instead of zero. The below image is my solution. Just add in a second one further down the line. Easy enough right? Well my question is this: Could I charge the batteries by tapping into each of these connections even though the ESC would also be receiving power? The batteries I have use a laptop charger outputting 25.2v. Exactly what my ESC runs off of and in theory, I don't see why this couldn't work out. It would save my a lot of hassle because I didn't design my enclosure very well in terms of charging the batteries. Without this, I may have to disconnect the enclosure from my board each time I want to charge. Anyway, thanks again for reading and I hope someone can lend some information.
