BYqSXt8Z
Hello all!
Just wanted to show my latest project; the little one was all excited about my ebike and the family's new e-car, so I bought a used powerwheels for my child for his birthday, and it will need a battery. At first I was considering making a lithium pack, but then it needs a BMS to make sure it does not go wrong (can't expect a small child to monitor voltage and put safety ahead of fun) and cost went up quickly, then I considered using 12v power tools, but the cost was a bit too high for what it was.
My latest idea is to used my ryobi 18v battery (at it again with those!) because ryobi sells their "battery meters" which is essentially a connector for the battery pack, I already have 8 batteries and three chargers, a bunch of meters, and they have a built in BMS.
It was pretty simple, I just soldered wires onto the meter and put it in place of the SLA battery's harness, and that's it! The inside of the vehicle is so large for the pack that he can carry around extra stuff in there (on the first use I put all the batteries in there just in case, and they all fit, 8 of em!)
In the end, it works best with the 4Ah packs. The 2Ah packs only work in "first gear", the BMS stops the device when he goes in high speed for more than 50-75 feet (which is actually good sometimes). But once at the park, where he wants to go in high speed all the time, the 4Ah packs are necessary. The 2Ah pack gives a solid 40 minutes of run time.
Here is a picture of the power-meter used as a socket. I used gorilla glue to hold on some velcro and a strap so that it can hold the battery in place.
