Kingfish
Keywords: Keywin, Start Transmit, Fail
Greetings –
I finally got my piece parts in to make my USB/TTL adapter so I can finally program my Infineon.
Unit that I have is: EB806XC-A-12, bought from eBikes.Ca, 6FET IRLB4040 25A (for 36-48V nominal).
Followed reference threads:
Using the Keywin software, I kept params nominal, no crazy stuff. The controller is disconnected from everything except the dongle.
There isn’t a lot of depth on this subject; if you do a forum search with keywords “transmit fail†it returns exactly six finds, four are from
120% speed advanced timing on the controller programming
Has anyone else had this problem? If so – what did you do to resolve it?
Thanks, KF
Greetings –
- Methods 100V 100A Programmable Regen Controller
- Keywin E-bike Lab Parameter Designer Software Manual-ver 1.2
- Headerless 18fet usb/ttl
- Hit “Start Transmit†and tap the +5V wire to the dongle to complete the circuit
- Software app gets about 86% complete on the status indicator (6/7ths progress) before the app indicates transmit “failâ€Â.
Thanks, KF
