cwah
Hello,
I've finally decided to add a seat to my bike:
I've already prepared anchor for the side of the bikes that would allow to put M6 bolts:
The principe would be similar to Thebikeseat, but with working for 20" wheel, with bigger box capability and working for full suspension bike:
Here's what I'd like to achieve:
Key requirement:
Able to support 75kg passenger at 30mph and small potholes vibrations
So there are 4 things I need to make sure are right:
- The pillar tube that needs to hold on passenger weight + box weight. I'm thinking to get 6mm thick * 20mm width bar for each side:
http://www.ebay.co.uk/itm/304-Stainless-Steel-Flat-Bar-Strip-10-15-20-25-30-35-40mm-x-3-4-5-6mm-thick-/252123870089?var=550966013650&hash=item3ab3c0f389:m:mKmAXQgsaPVW-Hva8fNkPig
It will be fixed by 1 stainless steel M6 bolt:
http://www.ebay.co.uk/itm/M4-M5-M6-M8-M10-A2-STAINLESS-STEEL-COUNTERSUNK-BOLT-CSK-ALLEN-SOCKET-SCREW-/181276846436?var=480302297717&hash=item2a34f12964:m:mgpaglHKBfZXoxcL7wueiFw
- The top of the box will use the same 6mm thick * 20mm width bar. The rest will use 2mm thick 20mm width bar.
- The hinge... I don't know what to get. Any idea?
What do you think about this plan?
Key requirement:
