cjh
Thanks for the detailed replies, I am learning from them.
cjh said:Thanks for the detailed replies, I am learning from them.![]()
beast775 said:Fellow,thats a slick non-ebike look.no getting caught speeding with that.![]()
fellow said:Thank you both. Yellow one is holding up well. Problems I had were faulty controller few months ago, and slight ATF oil leakage wich does not bother me.
Motor is untouched, I just unscrewed one of 6 disc screws, filled with ATF and used automotive grade silicon (for automatic transmissions) to seal those 6 screws. I have 3 Q100H, it leaks on some through the axle/bearing/inner races. I've never opened it, so I have no idea what it looks inside to be honest. No wires reinforcement. On my last ebike I use 75V, i prefer to increase the volts for torque instead of current as current increases heat and vibration ("pulsejetting/hammering"). At 20A+ and 54,6V, Q100H 201 rpm sounds unpleasent. Its fun for a minute, but tiresome for a longer rides. At 75V and 14A=1kw, motor is smooth.
I've never replaced oil, but I took an oil sample and it was grease contaminated. On my last Q100H 201 rpm, there is no leakage. Used 40ml there. I guess different baches of motors differ and leak more or not at all.
