Hello to all,
I have 16 15ah lifepo cells I bought in order to assembly 48V15Ah pack and I have problem to decide between two options of protecting and balancing cells.
First option is to buy full BMS system for my pack: http://www.ev-power.eu/SBM-CBM-1-1/Simple-Battery-Management-Board-16-cells-48V-60A.html
But I am concerned about voltage limits (3,9V HVC and 2,0V LVC), which seems too over the edge, I believe that those tresholds should be between 2,5V - 3,65V right? And another concern is about balancing current (72mA), which is pretty low. Here is how I believe this BMS work. I have misbalanced pack and one or more cells reach voltage over 3,65V, so BMS will start bleeding excessive power in form of heat, but because balancing current is too low, voltage continue to rise till reach 3,9V when BMS will cut off the charger, till those high cells are bleeded back down, but again because balance current is too low, those cells will stay above 3,65V for too long time right? Maybe I do not understand this whole thing right and everything would be OK with this setup, that is why I wanted to ask you
Those concerns brought me to option number two:
I would be two of these buzzer alarm: http://quadcopters.co.uk/lipo-battery-warning-alarm-buzzer-1-8s-182-p.asp which would be set to 2,7V LVC alarm and then buy 16 of these ballancing modules: http://www.ev-power.eu/SBM-CBM-1-1/Cell-Balancing-Module-3-60V-1-7A.html. They have balancing current 1,7A which seems sufficient for me (I will be using only 2amp charger), so they will not allow those cells to go above 3,65V. Drawback of this option is more cables and more room for potentional mistake but I should handle it
So what do you think guys?
