LamereCycles
- Joined
- Dec 28, 2019
- Messages
- 27
Willing to help with those tests with our proto bike. It has seen up to 22kw peaks without sweating
Powervelocity.com said:Four mosfets on each side of a phase, rated at 169A each.
So, yes, 676A total peak can be done. With 100v mosfets used rated at 240A, each phase can output 960A peak. Battery current can be bumped correspondingly. I will see if there is enough demand to do that. For now, 130v maybe 140v and 200A/600A combo looks reasonable for the application. I have no way to test beyond that at the moment but I see no reason why it can’t be done. I have to subscribe some serious testers to validate those power levels before it can be put in production.
Dimensions are 225x48x94mm. Probably the most compact size on the market today for the power it can deliver. It is likely the lightest as well. I will post the final weight a bit later.
j bjork said:Looks interesting![]()
But for now it is 400 phase A and 200 batt A?
Something like 600 phase A possible it the future?
What are the dimentions?
