I plan to squeeze has many charge cycles as possible of my lunacycle 52v-24ah pack.
I hear that the golden rule is not to charge above 80% unless you plan a long ride or want to balance the pack, and not let them drop below 20%.
So here's the question, the readings show around 50.1v, Battery 52v, no problem... but the built in metter, despise showing the same voltage, marks the battery whit just 2 bars out ot 6 of the overall indicator... so.. is it already at 20% at 50.1v? or the indicator takes that in consideration and considers 20% left as no remaining bars? should I recharge it already or make a few more rides until drops around 47v? What is the exact 20% of 52v battery?
The other question is how frequent must I charge at 100% to balance the pack, 1 time every 2 months? every month? The use of the bike is not too intense, I doubt I need to recharge it more than 1 time per week at 80% or even less, because the 24ah and limiting the output whit a 3 speed electric gear gives me a lot of range.
Is the aging of the battery another issue?
