John in CR said:
Santacruz said:
Hi all,
I have searched, but not really found a simplified answer.
That is pole pairs in a motor.
I take as an example, MXUS 3k - 23 pole pairs and a QS205 3k - 16 pole pairs.
So one has 46 magnets and one has 32 magnets.
Does this have something to do with RPM or torque or even reliability?
What is the difference and what is better to have.
As long as the motor can produce the torque you need and assuming all else is equal, the lower the number of pole pairs the better. That's because the iron core losses vary directly with switching frequency, and the less magnets, the lower the number of times the polarity changes per revolution. It's done to achieve a more efficient motor. The problem is that the stator will require few teeth for a good match of poles and slots, and that results in deeper teeth and more laminating steel, which is more expensive and generally heavier. The hubmotors I use have only 10 pole pairs, which a big part of the reason they have a peak efficiency of over 96%. Too bad they're out of production due to cost.
All else isn't equal though. While you can decrease hysteresis losses with fewer pole pairs to lower the electrical frequency of the motor, you can also increase the torque constant of a motor by increasing the number of slots and pole pairs. Since hub motors are usually operated in conditions where torque/copper losses dominate rpm/hysteresis/eddy losses, increasing torque at the expense of rpm losses usually results in more efficient motors.
John's "hubmonsters" aren't particularly efficient at making torque with specific Km (Nm/sqrt(W)/kg) values below those of many normal bicycle hubmotors such as MXUS3000 and TC4080 based on data from the "Motor Data V4.35" motor comparison spreadsheet. This is probably largely due to their low pole/slot count. The hubmonsters do have low enough specific hysteresis drag (Nm/kg) compared to the same normal bicycle hub motors to end up being more efficient, but I would attribute that more to quality design and materials rather than slot/pole count configuration. I would argue it is cheaper to make an efficient motor with lower slot/pole count since hysteresis losses are inherently lower, and deep slots mostly just waste less material when they are stamped out.
