As my first post I wanted to say hello and introduce myself. Having two kids I want to get a small 4 wheel cart going as well as possibly a scooter. To begin I started modifying their ride-on toys and with good success, I wanted to try a larger, more robust controller.
I picked up a Kelly 24V KDZ24300 mainly for their current 24V toy and to eventually upgrade later into a scooter or more durable 4 wheel cart or buggy. I thought I could use this as a reversing controller but later realized I need a reversing contactor so not a huge deal.
The current setup uses two 24V 50A DPDT relays along with a 1000W controller but those really aren't what I wanted for the higher amperage draw of the two 775 size motors but work fairly well.
Moving forward, I want to use the kelly controller with the current hall effect throttle and momentary push button brake on their existing 4-wheeler using the two 775 motors. There is a reverse lever but I will need a separate contactor for that, so forward only for now is fine.
I have the J2 harness and my main concern is will I need a main contactor with a resistor or can I wire the controller from a fused power lead without the contactor?
Just looking for tips to properly hook up the controller to avoid any damage as they aren't cheap.
So for now I will use two 12V batteries in series for 24V, 3-wire hall-effect throttle, push-button for brake, and a keyed switch along with a 50A fuse. I do have a RS232 to USB for the PC for programming.
All input and criticism is greatly appreciated.....glad to be here!
