Hi, my wife has a bike with a 36V KZQW22A controller. Based on the date stamped on the controller the bike is only about 18months old, and clearly hasn't had much use (allegedly it has been used and had the battery charged every week or so).
I have two questions.
1. The display loses power or switches itself off occasionally. There is no discernable pattern (i.e. it doesn't switch off when it seems like the motor is operating at full power or anything like that), and it can be switched back on immediately. I would like to troubleshoot, to determine whether the problem is the display or the controller or what.
There is a german guy selling these controllers at https://www.groetech.de/index.php?main_page=index&cPath=44, and he says you can run them without a display: "brown and red must be bridged with a jumper on the display port". I disconnected the display and jumpered those pins and it does seem to work, although I haven't actually ridden it. I am wondering if it is likely to actually be safe if we ride it like that, to see if the motor still switches off (if it doesn't then I guess the problem is the display, or the wiring to it). Or is it possible that the display has a safety feature that is turning it off because of something that isn't quite right, and it will be dangerous to ride without a display?
2. When using the throttle the bike is significantly faster than on the highest PAS assist mode.
The guy selling these controllers says on the pages for the "sinus hall" KZQW22A models that "the system is somewhat slower with PAS than with the throttle, this can be corrected by using a linear PAS sensor". Is this common behaviour, or is it peculiar to these controllers?
The only place I can find a PAS sensor described as linear is also on his site: https://www.groetech.de/index.php?main_page=product_info&cPath=4&products_id=598. It connects to the throttle cable. Are there other options, perhaps that would use the normal PAS connector instead of the throttle connector? Maybe there is another technical term that I should be searching for instead of "linear"? I'm guessing that sensor would work on pretty much any controller with a throttle connector, so even if I don't have the "sinus hall" KZQW22A model it would work?
Thanks.
Thanks.
