Quick (and probably stupid) question about the anderson tap
madnomad
1 W
UK
I just went to buy one of these:
http://www.ebikes.ca/andersontap.html
and then I noticed it has a 2.5a polyfuse. Does this mean I wouldn't be able to power lights which use more than 2.5a? If so that seems a bit low doesn't it? The light I was hoping to power uses 12v at 3.6a on maximum power mode. Does this mean I'd have to take it from the CA's power out?
It's 2.5A at battery voltage. if you're using a DC/DC converter to take power from battery voltage down to the 12v you need for the light, then you will get more amps out of the DC/DC converter.
For example, if you had a 48v battery and used that 2.5a tap, the limit would be 120 watts. (48v X 2.5A = 120W) If you plugged a DC/DC converter into that for a 12v output, you could have up to 10 amps out at 12 volts. (120W / 12V = 10A).
Ah ha! Okay, thats good news. Thanks for your help! :)
