hillyterrain said:
Will cycleanalyst be good enough or do I want to monitor on a cell-level, but how if I can't leave the monitor plugged in?
http://www.endless-sphere.com/w/index.php/Balancing:_What_is_it_and_when_is_it_necessary%3F
Personally I think the best option around for RC LiPo is Methods' protection boards, in the for-sale section. They wont' kill your packs leaving them attached (even for months!) and they will cut off discharge when worst-case LVC is reached.
HOWEVER: they are not an everyday-cutoff-level protection: they are a way to keep you from killing your pack, bursting into flames, or whatever.
So you would still want some other main LVC--in that case, you could use the CA to cutoff throttle at a pack-level LVC. I would recommend setting this to no more than 80% discharged voltage for your pack, so you dont' run the cells down too far (and to leave some wiggle room for your pack as it ages, or bad days on the road, you want a bigger one than you think you need anyway).
Regarding CellLog uneven drain, there are some "fixes" for this in variosu threas on the forum, including one by Fechter, and I think another by Otmar (his might've been for logging, I forget). But uneven or not, they still drain the pack when attached.
