Lurkin
Mine is to be shipped this week.
Lurkin said:Mine is to be shipped this week.
Offroader said:Lurkin said:Mine is to be shipped this week.
Any updates? Did it ship? Anybody?
My batteries should be here in a few days, and then in two weeks I should have my spot welder parts and will have everything I need to build the most incredible Q76R with a 3KW battery pack.
Really looking forward to this new build.
TheBMallory said:...I didn't expect to hear from him before a week or two !
TheBMallory said:oh yeah it is really thin ! I was a bit surprised, it's just a tiny bit thicker than an normal bike. I measured the inside and it's 72mm wide. I'll post some pictures tomorow so you can get what I mean.
As for the 5v, I'll only run 48v. I just did I quick search and found this :
http://www.amazon.fr/Gratuit-LM2596HV-r%C3%A9glable-dalimentation-Adjustable/dp/B00VAOIQ9M/ref=sr_1_6?ie=UTF8&qid=1455392913&sr=8-6&keywords=step+down+60v
(but it only gives 3A)
or this (way more expensive. what is the voltage of a fully charged 72v bat ? this thing works up to 75v) :
http://gryphondynamics.co.kr/product/gsr-7075-quasar-bec
TheBMallory said:I screwed up putting the starnut in place and now I have to order a replacement AND the proper tool to fit it in place (I didn't have one, I tried and lose).
You can get the right bushings for the frame if it doesn't fit. You will just have to measure.jmz said:Fox DHX 5.0 9.5" rear shock, measures as ~250mm long. Unsure if the existing bushings would be compatible, how generic are they?
IMOP, don't skip the rear brake. I have crashed a couple times when riding without the rear brake (had regen). That could be because I was expecting it to be there and forgot it wasn't but I still don't like the lack of control I "feel" without one. To each his own though...jmz said:F+R Hope Mono M4 4-pot hydraulic disks with 203mm rotors. The rear pot was going to be too large to fit in between the QS motor and disk without spacing the disk, but I'm not sure I want to space it and risk getting the motor wires caught up on the disk bolts. Could also go E-brake only on the rear, or get a 10" rotor and a caliper adapter.
I think all that will work. If you still want to run a multi speed freewheel in the rear, you can still special request the 165mm dropout from Qulbix but production time will be longer. Also, be sure to request the rear brake mount kit, the dropout reinforcement kit, and the rear shock mount kit if the dimensions look to work for your fox.jmz said:Electrical bits:
Adaptto Mini-E + 70A charge coil, BMS
Domino throttle
205 LG HG2 cells (was planning to do 20s10p, now considering 22s10p if it would fit, would only be charging to 4.0V, so 88V max input)
QS 205 50H V3 5.5T in 19"x1.6 moto rim, 18T freewheel, came with a few nuts and spacers, unsure if I would need anything else to fit in the 155mm dropout?
ecycler said:TheBMallory said:I screwed up putting the starnut in place and now I have to order a replacement AND the proper tool to fit it in place (I didn't have one, I tried and lose).
What happened? I have never used a special tool to fit a star nut. Did you send it too deep or get it in crooked?
TheBMallory said:ecycler said:TheBMallory said:I screwed up putting the starnut in place and now I have to order a replacement AND the proper tool to fit it in place (I didn't have one, I tried and lose).
crooked. I didn't have the proper tool so I tried this technique (spoiler: it doesn't work) : https://www.youtube.com/watch?v=K9Dy11NGBIE
As I can't get the nut out, I sent it deeper so I can put another one. I now have the proper tool and I should be good to go this weekend (http://www.amazon.fr/gp/product/B000QSUWI6?psc=1&redirect=true&ref_=oh_aui_detailpage_o00_s00)
I suppose... I tried with a screw too. When it started to crook, I tried to hammer to the side but it just bent the screw...macribs said:Can you use a diy tool like a threaded rod and force the star nut down? Kind of like how to mount head set without proper tool?
