I started to dismantle my raptor 165.
Happy that I won't have to deal with lipo packs anymore. Take a look at that mess, a few packs were puffed as is normal, and even a negative wire on a pack was torn off. I squeezed a lot of packs into my raptor 165, so I could never keep them from getting damaged. I am very surprised I never had any fires.
Getting those packs and wires in there for the side covers to shut used to take a very long time. I maxed out the battery space in the 165, similar to what I am doing with my new build. I'll be making sure the battery is much more stable and secure in my new build.
Old 2.3 KW lipo pack and wires weighed in at 38.9 lBS (17.6 KG) (including cardboard box)
NEW 3.5 KW 18650 pack weiged in at 30.8 lbs (14 KG) I would say about .5 lbs or .25 KG more weight to finish it.
So I get around 50% more capacity in my new pack, with a 20% weight reduction.
However, my 20C lipo packs could put out 700 battery amps continuous at 18s.
My 18650 pack can only put out 140 amps continuous at 20s.
Considering that I only use 85 battery amps (set in Max-E) with my lipo packs, most of the 700 continuous output was a waste of weight, so the 140 battery amps on my new pack should be more then sufficient. I'll probably only set it to 100 amps in my max-e, most likely probably keep it at 85 for 20s.
