rash from old streetlights? any insight?
jimmyhackers
i do the returns at a street lighting company. which means i come into contact with old grotty aluminum and plastic.
every now and then i get a rash from where my forearms have touched the lamps. light red rash, kinda feels like ive been rubbing fibreglass insulation, loads of little prickles.
my first thought was the plastics have fibreglass reinforcement but highers ups say apparently not.
any ideas?
Bird poop on the surfaces?
Airborne dust and debris on the surfaces?
Etc.
Or perhaps you have an allergy to the aluminum oxides or degraded plastics, etc.
I'd recommend handling with tough gloves (the kind with long gauntlets), and wearing a mask, mostly because of the bird poop, but they'd help anyway. Your workplace may even be required to provide those, depending on your local regulations.
Also, if those are mercury vapor or sodium (rather than LED), and any of the bulbs get compromised at any point in their lifetime, stuff from inside can end up on the casings, and that can end up on you.
Similarly, if any of them were painted or coated with anything originally, remnants of that can be on there too.
Pollen, leaf litter, sap and debris from Poison Ivy, and Poison Oak rubbing against the skin under various circumstances cause related rashes for example.
Fiberglass slivers are my absolute worst nemesis.
Based on your symptoms, and the fact that every non-metallic light pole I have ever seen has been FRP(I have inadvertently gotten rashes just from leaning on one at a street corner), I am fairly certain the highers ups have not been getting fiberglass rashes.🤒
Some close inspection can give a clue, take a flashlight, or sunlight, and shine the light flat-ish across the rash, from different angles,
some angles will refract the light clearly through the glass needles sticking out of the skin, all the proof you need.
SOLUTIONS:
1. In a pinch, use some decently sticky tape repeatedly on the fiberglass contact area, gently, you don't want to push them in further,
this will not get all of them, but will give some relief till step 2 (you can see how many needles the tape is getting with some light)
2. Use some Elmers wood/paper glue, Titebond 1or2, or similar, it has to be non-toxic, and release cleanly from the skin,
spread the the glue in an even, somewhat thick, but not too thick(or it takes forever to dry) over the rash area, let the glue mostly dry,
and gently peel the glue "scab" off, profit.
Some caveats:
Yes, some hair may get pulled in the process, but the short term pain is SOOO much better than a week long plus, irritated rash, now the rash
usually lasts 1-2 days max, and is far less irritated.
Glues: DO NOT use Epoxies, Silicones, JBweld, Superglue(CA glue), Polyurethanes, etc.
non-toxic childrens craft/wood glue or equivalent ONLY
Just my personal experience.
Adam
