nemondemon
Just completed my latest build on an RX200 scooter. Tried to keep it looking as stock as possible (electric scooters are increasingly poorly received by the UK police) with an emphasis on power rather than range. Only geared for 44mph but climbs hills like a beast. Also the rigidly tensioned belt drive conversion means motor braking (and therefore regen) is now possible. Specification detailed below:
Custom aluminium angle motor bracket
Eccentric rigid belt tensioner
14T motor pulley
5M belt (15mm width)
ANT 110A BMS with passive balancing
EDIT: ESC failed within 2 rides; now upgraded to a Flipsky 75200 Pro V2.0
Drivetrain - Full Belt Drive Conversion
Custom machined rear 72T timing pulley with freehub threadCustom aluminium angle motor bracket
14T motor pulley
Motor
Alien Power System 8072S 165KV 6000WESC
Flipsky 75100 Pro V2.0Battery
3x 5S 7000mAh LiPo running in series (15S total)ANT 110A BMS with passive balancing
Braking
Conversion to Shimano MT200 hydraulic disc brakeEDIT: ESC failed within 2 rides; now upgraded to a Flipsky 75200 Pro V2.0
