Having spent some time last night watching videos of people deliberately lighting off RC lipo pouch batteries by over charging (and in some cases mechanical puncturing after over charging), I'd like to discuss the probable combustion process and how it might be best contained.
This is all based on <5Ah, <6S single packs. High voltage packs may be different. I saw no evidence of electrical arcing or plasma.
Combustion
The combustion appears to be a mini-BLEVE (Boiling Liquid Expanding Vapour Explosion). Heat within the cell appears to boil the flammable solvent and create internal pressure. At some point the combination of heat and pressure causes mechanical failure of the pouch and the gaseous solvent escapes as a vapour cloud. If there is any remaining liquid solvent, some likely flashes to vapour due to the sudden pressure drop.
Having mixed with atmospheric oxygen the cloud ignites. I'm unsure whether this is because the solvent is already heated above its auto-ignition temperature, or if a short in the cell caused by mechanical damage during rupture provides an ignition source.
This creates the sudden fireball that lasts for a fraction of a second. The plastic remains of the pack then continue to burn, perhaps along with any remaining liquid solvent for several minutes.
Mitigation
Clearly, a non-flammable casing for the battery is a good idea. There's no point literally adding fuel to the fire. Preventing the second-stage of combustion, where the plastic burns should also be pretty simple - just exclude air.
What would be ideal is to prevent combustion of the gaseous solvent when it is released. Conventional wisdom seems to be to have a fireproof case/enclosure, but to add a vent to safely release pressure. This seems intuitively to be a good idea, but we must avoid the situation of this act simply becoming a flame-thrower. If a pack is the ignition source of the vapour cloud then a metal gauze over the vent will act like a Davy lamp and prevent combustion. If the solvent is above auto-ignition temperature then this won't work, although a sintered vent material might sufficiently cool the escaping vapour to prevent auto-ignition when it reaches the air outside.
A compromise needs to be struck regarding inside volume to allow some room for expansion (to reduce pressure) and to limit the amount of oxygen available for combustion inside the case.
Prevention
Mechanical failure of the pouch and subsequent combustion following extensive swelling and heating. Either of these could be detected by a temperature or pressure/strain sensor attached to each pack. It should be quite simple to create a circuit that will break the mains connection to the charger via a contactor based on input from such a sensor. I'd recommend the mains isolation option as an over-charging event could be caused by a faulty charger or BMS and we should not rely on them to stop charging based on sensor input.
Caveat
This post supposes the use of RC lipo because an application demands it, either because alternative battery chemistries or formats are inadequate on technical grounds or not locally available. This post is about trying to mitigate against the particular risks involved in using it. Not using is not considered a solution. I say this because the topic is not about how much safer lifepo4 or 2C 18650 cells are.
Combustion
Mitigation
Prevention
Caveat
