geek.guam
Greetings e-bike enthusiast,
I've been researching e-bike kits to convert my 1999 Bianchi Advantage Hybrid bicycle. It's an aluminum frame with chrome moly front fork. Except for the front tire, all parts are original. Here are some pictures.
I'm interested in a rear hub motor conversion, probably a geared motor for less weight. Current rear hub is 8 speed Shimano FH-MC38A freewheel cartridge. I just gave the bike a tune up and so I've ridden it a couple of times to work and back. I'm looking for a relatively painless e-bike conversion to make my bicycle commute a little easier. It's been a while since I've been riding, and I can see how an e-bike conversion will also provide me some much needed exercise for my 52 year old body.
Here are some other relevant info:
1. Desired max speed on level ground: 20 mph max. I'm not going for any speed records here. Just interested in easing my commute.
2. Desired max range at what cruising speed. mph or kph: I'd say causing speed is 15 mph, with a max range of 15-20 miles.
3. Wheel size of bike you want to convert: 700 x 38C
4. Brake type of motor wheel: V-brakes
5. Rider weight: 200 lbs
6. Terrain: Mostly flat with the occasional 5% grade
7. Budget: ~$800 with battery
I appreciate any advise you can give me. Thank you!
