Skrzypas
Hi,
My first post. I'm from Warsaw, Poland and this summer I started to prepare e-bike for the next season.
Well, I've started making a ~40 Ah (counting the rated capacity of gathered cells) battery from recycled laptop 18650 cells (3,7 and 3,6 V nom).
I would like to share my method for testing these (and probably suitable also for other) cells. Yet I didn't start to discharge cells so any opinions and comments are welcome.
The goal is to make a pack from recycled cells that will be reliable and repairable.
Up to now:
1. I've bought a few cheap 18650 chargers for 1 cell (works for pair pretty well)
2. I have access to an Electronic load on a daily basis, so I can make programmable discharge of cells
New method is proposed since the pack must be reliable as much as possible, and plenty of time is still left for the machine launch:
1. Charging cells to 4.20V-4,25V
2. Waiting, occasionally writing down voltages of all up-to-now charged cells
=> result - discharge graphs, V/month self discharge
3. Cells with excessive self discharge are put on another pile.
Well, I see that most of my original thought was actually not posted:
4. Equalizing cells at 4.200V (note 3 decimal places) +/- 5 mV
5. Discharge in a following manner (with 1s data acquisition):
When I test high enough number of cells, I will arrange cells in a following way: each 20P sub-pack will get cells of
a) Similar resistance and capacity
b) if possible: Similar shape of discharge curve at 1A
And so:
Any suggestions/corrections are welcome.
Up to now:
- a) OCV (open circuit voltage) 10s (0A)
b) CCL (constant current load) 12 min (1A) -> 1A is my system design point for ca. 2000 mAh rated cells
c) OCV 5 min (0A) -> 5 minutes time will be adjusted, since I did not check how fast the OCV rebuilds in laptop cells
d) CCL 12 min (1A)
e) OCV 5 min (0A)
f) and so on, up to voltage = 3 V@1A -> not to stress the cells too much
- - Capacity@1A [mAh]
- OCV in function of drawn mAh (discrete - one point each 12 minutes = 200 mAh) [V] - for SoC determining
- V@1A in function of drawn mAh (discrete, 200 mAh) [V] - for determining real battery operation time in the design point
- Resistance in function of drawn mAh (discrete, each 200 mAh, R=dV/1A) [Ohm]
And so:
- - Small variations in cell resistance between cells (in each 20P sub-pack) will allow equal current passing through each cell in the pack in each DoD.
- Similar capacity will allow draining cells equally to 3.0V (BMS cut off).
- Shape of discharge curve gathers all above information in a continuous (not discrete) way.
