My $300 Asian Ebike has an 7.8Ahr 48V Battery pack that failed at 444 Charge/Discharge Cycles. Here is my experience replacing and repairing the Battery pack.
Use Details:
26" Wheels, 21 speed, 75lb steel frame, 750W Peak Motor with pedal assist and/or throttle.
Battery: 13Sx3cell parallel pack consisting of 2.6Ahr 4.2V 18650 matched cells. Integrated BMS with Passive Balancing Circuit.
8 mile 35minute bike ride on hilly terrain consuming about 3Ahr.
Charge several hours from 'red' to 'green' balanced condition after every use.
Full Charge Voltage: 54.8V (4.215V/Cell). Balancing starts in 'green mode' at 4.1V/Cell.
I replaced the failed pack with a larger 10Ahr 48V battery but realized that all the major 18650 LiPO cells all have a rated cycle life of only 300 to 500 cycles! This means that at one 3Ahr 35minute ride per day followed by a full ‘Balance Charge’; one needs to replace the ebike battery pack every 1.5 to 2 years. Therefore, I decided to repair the old ‘worn’ battery pack and see if I could extend the life well beyond 500 cycles.
Key take-aways: Battery balancing may not be necessary and Full Discharge (below 3.6V/Cell) and Full Charging (greater than 4.05V/Cell) limits battery cycle life. (By using the battery between 20% and 80% capacity, there are reports that cycle life can be extended to up to 5000 cycles).
Bottom Line: The initial results are encouraging. I may have salvaged my aged pack by cycling the battery only between 20% and 80% of capacity and foregoing and full charge/balancing. I am no longer fully charging my new 10Ahr battery pack and my 3Ahr typical discharge is easily achieved within the 20% to 80% capacity range. Note: A timed 1hour charge with the standard charger is sufficient to charge the battery after the typical 3Ahr ride.
Use Details:
- Battery pack failed because one of the cells in the 13Sx3 pack discharged to 3.0V while all the other cells were closer to 4.0V. (The BMS shuts down the pack output when any cell drops to 3.0V or less). The ‘Low V’ Cell has similar 90% SOH (State of Health) as a ‘Good Neighbor’. However, it lost capacity 28 times faster (14% Voltage loss versus 0.5% over 30 days at room temperature). This abnormal leakage could not be resolved with the internal passive balancing circuit on the BMS. (See attached graph.)
- 3 more cells failed after the initial repair after only 24 more use cycles with the same low volage failure signature.
- The Battery pack was modified with a 14 pin external port so that all 13 cell groups could be monitored and custom balanced. (See attached photos). Since the 12 new 2.6Ahr non-exact replacement cells could not matched to the older cells; all the cells were manually balanced to 3.65V +/- 0.010V. (See attached graph). The cell miss-matching does not cause problems since none of the cells are stressed outside of the 20-80% safe operating envelope.
- The Repaired battery pack was successfully used for 25 cycles where pack was used only between 20% and 80% charge level using a non-balancing timed charge.
- Battery balance was preserved at 3.65V after 25 cycles and all 13 cell sets had low leakage (low self-discharge).
