SkyCaptain
- Joined
- May 25, 2009
- Messages
- 41
Hi all.
Any ideas please please please.
(My question is near the bottom,,, so you can speed up and shoot down there if time is scarce)
Motor, Clyte 5304
Had been working perfectly.
Stopped working.
Deduced it was the motor,( by trying other motors on the same controller)
Then confirmed two hall sensors were dead.(made up a plug, with 6.5 volts, and used my multimeter doing it the way it is described on here,,,,thanks guys)
But actually, while checking them, it was not that clear to me. Should they drop down to Zero volts as I slowly turn the wheel? or just drop a bit?
Anyway, two of them had not fluctuation at all.
Bought three new ones for $30 AUD lol,
replaced them, in the same orientation, and I believe I got all the wires the correct way around.
Put motor back togother, and it seems that two of them are dead again,or still not working
So, to be clear, I worked out that two halls were dead so I replaced all three with new ones.
Now, after replacing, it still seems like two are dead again.
I have checked that each wire going to the hall has continuity, between the where the hall plug goes into my speed controller, all the way up to 3cm away from the halls.
(the final bit of wire goes under the big coil)
But each of the five wires going to the halls does not seem to have a break in it, at least all the way until the last 2 or 3cms worth.
So, any ideas? Seems kindah funny I have two halls down again, like at the start when it first broke ther was also two dead halls.
Does anyone know if I can put new ones in again, and this time around run the wires to the hall sensors over the big motor coil wires? (instead of how it is now in original form, with the wires tucked under the motor coil wires)
Is that a good idea?
The wire on the halls was only about 4mm long, so I cut the new halls down to the same length.
Maybe the heat from soldering the wires on?
I did it pretty quickly and good, but I did stuff around and have to had to have a few goes at on or two of the wires.
Can I test the sensors without re assembling my motor each time?
Like, should I be able to power up the halls with my tester, and then swipe a magnet past the halls?
I did try that, and could even get a response from the working hall.
But when I put it all back together, I could see that at least one of the halls was working.
(just a pain to keep putting the whole motor together each time just to check my hall, which don't seem to be working lol)
Question,,,,,,I guess, the best help would be to know how to test a hall out of the motor.
Do, I just power it up and swipe a magnet past it?
That way, I can test the three I removed, and also the three new ones I just installed.
Should it drop to zero volts when I swipe the magnet?
I did check with the local shop who repairs these motors, and it was going to cost a fair bit of money which I don’t have to get it fixed.
Actually I am that sad and dejected by this whole mess I am seriously considering selling all my clyte motors, because they are the only brand I have failures with.
My GM's which are much older are still going very strong.
Anyway I no complain.
Just sad I can’t seem to repair her.
And have no idea how or what to look for next.
So, I take that back about selling my clyte motors.
Please, someone help, Obi one, are you there?
I don’t want a pickle, I just want to ride my clyte bicicle.
Thanks.
Motor, Clyte 5304
Stopped working.
Thanks.
