Hi, Im looking to restore some old battery packs I got laying aroud to see if there are good replacement cells that may be a good choice instead.
Originally they are equipped with Sony/ Murata VTC3 and VT5 depending on age and capacity.
I know that these are really good cells, and they use to last very long. Many times 2-3000 cycles before capacity is that low so that the machine cant go home by itself anymore. The mean current draw on these machines is not that high, usally a 5000mAh pack lasts for around 3h operation, and with some margin in SOC of cause.
Charge on the other hand can be up to 0.8C and it could be a sunny hot day or cold.
I guess most after market packs use energy type cells because they are cheap, but probably with shorter life of the pack.
So focus must be to find suitable good priced cells that can make a almost as good pack as the original ones, with service life as close as possible.
I have been looking at EVE 25P and 33V as a good choice that is not that pricy. Could these cells be a good choice?
Some advice would be apreciated!
Thanks
Thanks
