Hello
I was not able to find a topic like mine, sorry if I missed it.
I have an old Taiwan Cyclone BLDC middrive system.
Its 24V 350/500W (arguable) with built in controller ( inside motor behind gear train )
This system has worked well for me for many years.
I mainly ride flatland inter-urban, the motor is used as assist only.
I had to repair the FET's once and never got the PAS to work ( so it's disconnected![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Now the pcb has gotten damaged and I want to replace the controller with an external control.
I prepared the motor by removing all components on the pcb, leaving Halls and bringing leads out.
This gives me +5 gnd Hu Hv Hw U V W and 2 wires for stator temp sensor.
The motor is 120 edegrees and the Halls work ok.
I have very limited budget and am retired in upstate Thailand.
My old hall throttle twist grip and 12AH 24V LiFePo4 pack work well too.
I <think> I need a BLDC controller 24V 500W with suitable throttle
PAS and displays are very optional.
When i search for 24V 500W BLDC controllers
I find may small pcb units that have no hall inputs ( i think for rc planes)
I find BLDC spindle drives for small cnc machines ( eg WS55-220 )
I also find typical extruded aluminum boxes with octopus of cables for ebikes.
I discount the small rc plane pcbs as they have not enough FETs and no Hall inputs.
( methinks actual halls is better than extrapolating rotor position becuz its already there -
The BLDC spindle controller looks feasible,
but was designed for normal operation of
very high rpm motors with light(comparatively) loads.
Are they worth trying?
They are nice neat and small ( and logical to me, an ex-cnc repaiman )
https://tinyurl.com/yyoqe8ry ( good today 30sep2019 , else google WS55-220 )
( 30 bucks shipped here from my source (not ebay) )
Else,
I have found the classical e-bike drives and consider this package from aliexpress,
24V 500W kit with bigger LCD display (60 bucks shipped here)
https://www.aliexpress.com/item/32944472302.html?spm=2114.12010612.8148356.13.7a357b42vkkqLr
and will use my existing twist grip hall throttle and existing battery
so,
can I use a spindle driver
or ,
is the package suitable?
thanks tjtr33
Else,
so,
or ,
thanks tjtr33
