firetv2097
10 µW
Hi all,
I have an Engwe m20 battery that has failed due to what looks like a failed battery level indicator. I heard a "pop" when i pressed the indicator panel. Which then caused my battery mount plate to fail.
Below are pics of the discharge cable (i think) that has two fuses attached. One is ok, the other has clearly blown.
My question is, should i disconnect the red or black wires from the bms before attempting to solder on a new section of wire with new fuse attached. Is it safe to just cut the wires?
I woud love some help/guidance of this.
many thanks
many thanks
