Andje
- Joined
- Aug 25, 2010
- Messages
- 779
Hey all,
So i'm planning on getting a cyclone mid drive soon. I know it uses a 3 wire hall effect throttle connection, and i'd really like to be able to build my own throttle out of a potentiometer. I hate all the twist throttles, and on my gas bike i use a brake leaver as the throttle. I would just rig a brake leaver to a mounted platform via brake cable and then have a spring loaded situation probably with small plastic pully to increase the potentiometers diameter.
Is it as simple as getting a Hall effect potentiometer with proper voltage/ohms?
Series HRS100 Hall Effect Rotary Position Sensor
http://www.potentiometers.com/HRS100.cfm
Or am i way far off here in the deep end
? I'm the first to admit zero to no proficiency in electrical; i can learn though...
