RLT
help?!?!
I just ran the first test on my first 36V 20AH (4P 10S of 32650 5AH cells) Lithium Ion battery pack.
I'm using this BMS:
http://www.batteryspace.com/index.asp?PageAction=VIEWPROD&ProdID=3558
Everything seemed to be working properly; Discharge fine, Amp limit fine.... (Didn't run it down low enough to see if low voltage cutoff is correct, but I'm not really concerned about that anyway). Charged the batteries up, that seemed to work just fine; When I took it off the charger, I noticed that all the power resistors were pretty warm. Not alarmingly hot, but warmer than I'd like... Probably well within component specs though. So, I wasn't too worried.
Checked each of the serial cell groups. All were at 4.21 to 4.23 V , (individual cell balance of the BMS I'm using is supposed to be 4.22V max) and the entire pack was right at the 42.2V it was supposed to be. I noticed that the resistors were still pretty warm, but no big deal. I turned off my main power switch (between battery pack and BMS on the negative pole line) and worked on something else for a while.
About a half hour or so and when I went back, the resistors were hotter than they were right when it came off the charger.... And with the main power to the BMS off... the only connections to the board were the thin little cell balance wires that go to each series battery group and the positive wire. At that point, I unplugged the balancing socket just to be safe.
So, despite main power being off, was the BMS still trying to bring each cell into perfect balance by burning off energy???
Did I maybe wire it wrong (although it is correct according to the wiring diagram)????
Is the board maybe defective????
Assuming that there isn't a problem with the BMS or my wiring, are you SUPPOSED to leave the main power ON between the battery pack and the BMS ? According to the specifications the BMS only draws 300µA, so that isn't really a big deal, but I figured for safety, it is better to shut off main power.
Thanks in advance.
I'm using this BMS:
Thanks in advance.
