I don't know about the Revopower motor specifically, but here's a 15cc motor that makes 3hp:
Now that's an interesting idea! The Yamaha 1000i is the lightest commonly available generator that I've seen.
xyster said:Now that's an interesting idea! The Yamaha 1000i is the lightest commonly available generator that I've seen.
And that Yamaha generator weighs 28 lbs and produces 1000 watts.
Those rc engines weigh 28 ounces and produce twice the power. Even with 50% conversion efficiency, the rc-based system should produce the same 1000 watts of electricity for a lot less weight and money. And you can run the lil' engine only at it's peak efficiency or power point. The rest of the stuff for the power conversion shouldn't be heavier than a 1000w motor plus pwm controller....
Cut em a little slack dude. Most peeps are driving around in 3000 lb trucks. These guys are just trying to help. You say you havn;t seen one. Well GO SEE ONE or quit slinging slanderous statements. They are exhibiting at the powersports show next week.
Ypedal said:Well.. along those lines.. 80v x 40 amps is not exactly " legal " either :wink:
I plan to get my hands on one if they ever do produce them.. have been waiting and checking in every few months.. for a few years now...![]()
Would be convenient for extended range use..
Lowell said:Ypedal said:Well.. along those lines.. 80v x 40 amps is not exactly " legal " either :wink:
True, but a cop would have to do some work to prove it's over the legal limit. It would be pretty hard to convince a cop that the Revo wheel isn't internal combustion. Maybe it could be disguised as an electric hub motor, and put some fake batteries and wiring on board? If the Revo is as quiet and non smokey as they claim, you probably would not hear it over the sounds of normal traffic.
xyster said:Well.. along those lines.. 80v x 40 amps is not exactly " legal " either
Illegal does not necessarily mean more harmful. On the continuum of environmental and noise pollution, two-stroke engines reside far towards the 'bad' side. So long as you don't run me over by riding fast and reckless with extra electrical power, that 'illegal' use is no skin off my nose.
