richard purchon
- Joined
- Dec 10, 2012
- Messages
- 29
I burnt my 500w bpm cst motor out.
this motor has been bad news since it got it from bms battery.
it arrived damaged with a bent spoke flange,only got 35 spokes.
it should be 270rpm but its way faster than another one I have.
10cells 26" wheel 25mph. 15 cells 35 mph great,but the battery doesn't last long and when it comes to a decent hill its melted.
so I decided to have a go at rewiring.
first dismantle the motor and take some pictures of the stator.
where the wires come out cross over etc
remove and save the tabs in the slots.these keep the wires in the slots.
carefully unwind the wire from the stator starting at the wye connection [oppsite side from phase wires]
take note how many turns of wire there are around each slot.
this determines the speed of the motor.
try to get one the of phase wires off complete, so you know how long the new wires needs to be.
my motor had 5 strands of 0.5mm wire wrapped 8 times around each slot. 6 in total
here is a link to motor calculator.how the motor is wound.
the bpm has 18 slots. 16 poles or magnets.double layer and is y connected
http://www.bavaria-direct.co.za/scheme/calculator/
