mate! WTFFF are you doing!
Sounds like your trying to make this job 3x harder for yourself.
doing a few strands at a time is not the go...I'm pretty sure anyway, never tried it, can't see how it'd make anything easier at all
did you read this reply I sent you before from my build thread?
oldhaq said:
Trackman417 said:
I'm going to start winding this weekend.... Hopefully. I have two spools of copper wire. And I want 10 strands of the stuff. Do you recommend wrapping wire around two poles 5 times cutting it at bother ends and winding all the wires together?
If you don't understand what I just said.... How did you set up your wire for winding? Lol
I put 2 sticks in the ground 15.5 metres apart, and made 4 loops to give me 8 lengths. you only need to cut after the final loop - just twist all together at the corner at stick. So I had effectively a 15.5 metre multistranded wire with 8 strands in it. I then just wound this 15.5m long wire onto a large upside down bucket to keep it neat.
Sounds like you were on track to this point, but then you've gone and split the strands up again?
I think KISS applies here
mate...just go the 10 strands together, you'll be done in no time
