Tommy L
Look for threads, but I'd have to revive one from Dec 2012
I've had to make a battery for my Bionx system on my Catrike 700. For the past year or so, I've put my 25lbs of LiFePO4
in the top on my rear bicycle rack in a padded backpack made for a Laptop. Barely fits....ok, doesn't really fit
That isn't the issue. If you have a trike with a rear rack and have placed heavy weight up there, it's a cornering
issue. Too much top weight! I thought it would be ok, since me the driver, is down low at 190lbs. But 25lbs
above your head is just bad for gravity.
I've ordered the Catrike 700 ARKEL Frame bags yesterday. I'd like to see what I can stuff in them, But they are NOT waterproof
But easy enough to maybe cram some cells in there. Makes for an easy mounting solution.
I purchased a couple of these from our local Canadian Tire Store. No O-Ring, so probably not waterproof.
Then you have to find a way to mount them. Nice to mount making them removable. So the engineering mind has to go to work.
This guy found some hardware for his DIY Panniers, almost the same method that all panniers use for mount/dismount.
These are available from our local Canadian Tire Store, I've seen them on Amazon too!
MTM Sportsmen's Plus Utility Dry Box
And finally, a company that makes a hard plastic pannier for bicycles
http://www.bikebins.com/
Tommy L sends....
Tommy L sends....
