Hi,
I'm trying to order rims for my BMC hub motor. Was looking at www.niagaracycle.com
Some rims are listed with say 26 x 1.5 or 26 x 2". How is the 1.5 and 2 interpreted? Obviously not rim width, but hopefully related to it.
Basically I plan to run Schwalbe Big Apple, 26 x 2.35, so I wanted a pretty wide rim, and obviously strong. Niagara has the schwalbes for only $33, and shipping is reasonable. I was hoping to buy the rim there also.
Sun Rhyno rims are mentioned a lot on ES. I'm guessing the XL ones would be slightly higher grade. Didnt see XL's in 36h at Niagra unfortunately.
www.niagaracycle.com has these:
Sun Alloy Rim 26 x 2.00 Ryno Lite Black 36 Hole $28
Sun Alloy Rim 26 x 2.0 BFR Mammoth With Strip 36 Hole $35
Sun EQ31 26", 36h PV Disc Rim, 559 ISO, Black $50
The last is a disc rim which is ok. I hope to keep the rear disk brake.
Which one would you recommend?
Any others?
I'm also going to be in the MD/DC area (Baltimore and College Park visiting some shool friends) in two weeks so you know of a bike store with good prices and selection I could pick up a rim then.
Thanks,
Martin
Any others?
Thanks,
Martin
