gestalt
I've been downloading all kinds of survival videos off of YouTube onto my spare iPhone as kind of a "bug out device" and I came across these things called rocket stoves. You can make them out of ductwork, bricks, cinder blocks, steel tubing of thicker walls for durability or my choice tin cans. Basically for the concept of using the cheapest and most available materials.
The principal is that they achieve a very efficient heat generation by using air flow and vortex forces to not only burn the wood, but also the wood gas. The result is a nice hot, smokeless stove that can cook food with very little fuel. They are promoted and used in the 3rd world, but I find that they could be very useful for camping, survival or just a fun alternative to using the kitchen stove in a urban environment.
To build mine I took three large soup cans, like the family sized ones. The concept is to make a "L" shaped tube, the bottom of the L is split horizontally. The fuel is burned on the top of the split and air comes in from the bottom. When the air, flame and woodgas hit the elbow something like a toroidal vortice makes a complete burn. I just mitered one can into the other at a 45 degree angle. I used a section of a third can to extend the chimney a bit. Some aluminum tape seal the joints. The platform that the wood burns on is made from a piece of scrap from one of the cans pounded flat.
It fired up right away and the only smoke was obviously from the coating of the cans and the glue from the tape burning off. Now the first order of business is to see how fast it it can boil water. I filled the kettle and used some box tube to make a space between the kettle and the opening. This narrowed the chimney and provided only a small strip of the base of the kettle actually getting heat. So these weren't optimal conditions. Soon I will be using two #10 cans to make a housing with the space between being filled with wood ash as an insulator. A BBQ grate will provide a good surface to place cookware.
16 minutes later...
The kettle is whistling Dixie and my tea is delicious.
I also came across this guys build http://ecorenovator.org/forum/biofuels/1052-building-rocket-stove.html and it is a great example of an institutional grade rocket stove. He grills, roast, boils and bakes with it made from a old water heater tank and some scrap steel.
16 minutes later...
