Well here it is, a RockShox 35 fork fitted in a Boardman MTR 8.6 frame. I am going to check the head angle which as standard is said to be 66 degrees, I was going to do a mullet job on it but 27.5" rear and 29" front might be a bit severe, will have to look at tyre options otherwise will stick to a pair of 29" wheels. I can do an offset bush job on the rear suspension and with the RockShox 35 fork I can open it up and reduce the stoke from 140mm to 130mm to offset the adapter. But before all that I must check the chain-line for the TSDZ2 mid drive now I have reversed the lower pivot pin. Aiming to build a updated version of my Boardman Team FS 650b which is fitted with 26" wheels running 2.5" tyres with a 320mm BB height.
