RVD
ok, i had a somewhat scary thing happen to me today.
i was leaving for work this morning and all was good but for some reason, right after leaving my driveway i wanted to go back home and make sure that my front door was locked. so i went back home and got off my bike. while my hands were still on the handlebars, the bike just accelerated at 100%!
luckily i was still holding the bars and out of instinct, i held tight so that the bike would go flying away. however, the rear wheel was moving and the bike is heavy so i couldn't just lift the whole thing up. i was basically moving the bike in circles with my hands on the bars so it was like i was standing there while the bike is going around doing wheelies.
at first i thought that maybe the throttle was stuck or something so i played that that but no go.
then i realized that i made another good move awhile ago (in case something like this happens?) by creating a little kill switch. it's a small red-red loop that i plug in to bring current from the battery to the controller. i found it and pulled it out and voila...stopped.
it was obviously a somewhat heart wrenching 10 seconds and probably looked kind of funny.
now time to troubleshoot...
i tried everything again by unplugging and re-plugging everything but when i put in my little kill switch loop thing, the same thing happened. this time i was lifting up the rear wheel so no drama but still.
this was with my e-bikekit direct drive rear hub motor wheel + lyen 9 fet controller.
i thought maybe it was a problem with the controller or motor (hall wires or whatever type of stuff like that) and luckily i had my crystalyte hs3540 nearby and lyen 12 fet controller (sensored) so i hooked all that up to my bike and...nothing. well, i had some issues with this setup before (i think maybe the halls are bad on the motor) so i had one more thing...my lyen 12 fet sensorless controller so i hooked that up.
and as soon as i put everything together...same thing! full throttle.
my only thought at this point is that the throttle is bad? somehow it got shorted or something so it's always registering full current?
any other thoughts?
any other thoughts?
