Jil
Hello,
I want to run 2 batteries in parallel on my ebike, both home-made :
- 52V, 14S-6P & 14S-4P.
- identical BMS for both batteries : 35A, single port (for charge and discharge).
- identical cells (Samsung INR35E, 3450 mAh).
- the controller is a Phaserunner, the motor a GMAC.
- I use my ebike between 20A and 30A battery output.
My guess is that there is no problem to run and charge them in parallel, but I prefer to check with ES first, in case I miss something :
Question 1 : is it possible to run them in parallel without risks ? Of course, before connecting them I know that I need to have them at the exact same voltage.
Question 2 : when charging, no problem to use one charger (4A) for both batteries connected in parallel ?
Question 3 : in case the BMS have slightly different settings for voltage cut-off, I think it's better to charge them a little bit below the max (ie. around 57.5-58V, instead of 58.8V), do you agree ?
Thanks for your help
