Pantera_666
New here
- Joined
- Sep 26, 2019
- Messages
- 18
Hey guys! New user here...
So I’m new to the ebike world, but not new to electronics (and common sense...) and I’ve been doing a lot of research about hub motors, controllers, batteries, etc...
Mostly (I think...) I have all of the basics figured out. When it comes to batteries (volts, amps, a/hr, c ratings, etc) I have no questions. Hub motors (efficiency, windings, rated watts, wasted heat, hot rodding, hall sensors, phase wires, etc) I’m 80% there. Now when it comes to controllers, I got the basics (and a bit more...) covered but there’s something that I still can’t wrap my mind around when it comes to displays or lcds...
So here’s the issue:
I want to get a Sabvoton controller installed on my ebike, running @ ~60A, AND with a 750c display (I don’t want a CA, I just don’t like it...)
Now Amazon sells a Savoton that is 72v 150A, and it’s on prime, comes with the Bluetooth dongle too. Not a problem, I can limit it @ 60A through the app, but... IT DOESN’T COME WITH A DISPLAY OR THE CONNECTIONS FOR IT!!! Bummer...
Then Ali Express sells exactly what I need. Sabvoton 72v60A (smaller in size too, it’s the 60A model) with Bluetooth dongle and waterproof connections for a 750c display, brakes and throttle (julet t4). But we are talking about Ali Express, aka long shipping time, lost packages, no reasonable returns/warranty, and the risk of getting ripped off by the seller...
So I was wondering if it’s possible to rewire either the aviation connector on the outside of the 150A model, or to take it apart and wire a Julet (5pin only or t4 would be amazing...) connector to the board, so I can connect it to a 750c display...
My reasoning is that a 750c display (and similar 5 pin displays) have 5 signals: ground, 5v, batt+, rx and tx. To my understanding this 72v150A Sabvoton controller from Amazon comes with these signals, it’s just not wired with a julet connector (either a 5pin for display only or a t4 julet for display, throttle and brakes...)
Here’s the link for the amazon one, 150A:
https://www.amazon.com/QSMOTOR-SVMC72150-controller-2000W-3000W-Controller/dp/B07D7TLQVN/ref=sr_1_9?dchild=1&keywords=Sabvoton&qid=1569508301&s=gateway&sr=8-9
And here’s the Ali Express one, 60A with 750c and t4 julet connectors:
https://www.aliexpress.com/item/TFT-color-display-Bluetooth-Programmable-Waterproof-Sabvoton-SVMC7260-controller-for-Electric-Bicycle-Bike/32234551877.html?spm=a2g0o.productlist.0.0.713d3476ECFO3g&algo_pvid=83f063bf-79d3-4767-803a-22c7b6457e43&algo_expid=83f063bf-79d3-4767-803a-22c7b6457e43-5&btsid=3830a366-a44f-45f8-8e80-b318b20a186f&ws_ab_test=searchweb0_0,searchweb201602_5,searchweb201603_60
Does anybody have experience with this? Do you guys think it’s possible?
Thank you for your help!
